Rekluse clutch on a 450 2015
  • N Johnson
    by N Johnson » Fri Mar 23, 2018 1:13 pm
    Anyone fitted a Rekluse clutch to a 450?? need some help and hopeing i'm just having a blonde moment.....
    fitted the clutch (COR EXP) as instructions and even checked the online video but still seem to be having what appears to be a problem, should the throw out move in/out once the pressure plate has been fitted and tightened down to 1&2 as instructions?? assume not as there is no resistance on the clutch lever/lifter on the other side ?/?
    as said hopefully i am having a "total" blonde moment here and i'm missing something.....
    cheers
    Re: Rekluse clutch on a 450 2015
    by JimDirt » Mon Mar 26, 2018 9:18 am
    Figured someone would have replied by now
    Have you tried contacting Rekluse directly , they have decent customer service , and should be able to walk you thru any issues over the phone https://rekluse.com/contact-us/
    I can't specifically answer your question as i don't use them , so i am not familiar with the install/adjustment procedures , but i do know that any issues you have they have most likely encountered and can address it easily and walk you thru it , they are about 60 miles from where i live and i know a lot of people use them here on newer CRF's
