Are you using the right screwdriver for your Japanese bike?
    by Aussiecrf230 » Fri Jan 19, 2018 3:07 am
    I was asked the other day why I didn't seem to have any trouble with crosspoint screws on my bikes as none were mutilated or rounded out. My answer was I use the right screwdriver. It is something I learnt years ago when Japanese screws (and bolts) were soft as butter. I have had my set for ever and they have always kept me out of trouble.
    You should be using JIS (Japanese Industrial Standard) screwdrivers. They do work on phillips and pozidrive screws as well and since they don't cam out the screwdrivers themselves last longer too. The best brand is Vessel (Made in Japan) and are available at good tool shops. What amazes me is so many dealer mechanics don't own a set. Some of the bike tool kits do have the bits so check they fit properly before replacing what you have. Pushbike shops that carry/ work on Shimano gear changers will also often have them for sale.
    Hope this helps someone killing a screw on your bike or carby.
    Re: Are you using the right screwdriver for your Japanese bike?
    by Back2-2 » Fri Jan 19, 2018 6:13 am
    Agree with Aussiecrf230 100% ! =DD There is a difference and it makes a difference! Many people will say that that a regular cross point # 2 works fine but once you actually use the correct JIS #2 or # 1 driver you will feel and know that it is the true correct driver.
    Buy a set, do yourself a favor and make yourself a better mechanic. ;)
    by crfsonly » Fri Jan 19, 2018 6:26 pm
    Excellent point and I have been amazed as well.
    https://www.crfsonly.com/catalog/produc ... ts_id/5373
    Because so many do not use the proper tool we offer these replacements for the master cylinder screws:
    https://www.crfsonly.com/catalog/produc ... ts_id/4673
    For the float bowl screws we offer these:
    https://www.crfsonly.com/catalog/produc ... ts_id/4498
    Ken
