Turning the clutch slave cylinder
  • hv2hunt
    by hv2hunt » Tue Nov 14, 2017 7:20 am
    I have an 2006CRF250X and I want to change the clutch cable mounting over to the R model. I have the cable routed and the R bracket mounted on the left side of the motor when sitting on it. I do not know how to rotate the slave cylinder around to accommodate the R position for the cable to connect to. It still has the electric starter on it to, I figure it will be close to the actuator arm. Thanks for the help.
    Re: Turning the clutch slave cylinder
    by crfsonly » Sun Dec 03, 2017 7:14 pm
    Welcome to CRF's Only. You haven't received a reply before now because no one has likely attempted this modification. What is the motivation for wanting to do this?
    Ken
