Engine rebuild
  • pappa t
    Engine rebuild
    by pappa t » Sat Sep 30, 2017 3:00 pm
    I've just bought a 2006 crf 250 x,I don't know any history of the bike so I've decided to rebuild the engine.
    What should I be replacing? I know the valves give problems on these so I will change them.
    Big end bearing seems ok but should I change it just to be safe? What about main bearings,transmission bearings etc.
    Any advice would be appreciated.
    Re: Engine rebuild
    by crfsonly » Sun Dec 03, 2017 7:27 pm
    Welcome to CRF's Only!
    If you are replacing the valves the seats need to be professionally cut. We offer these services a long with all engine parts required. When replacing valves it's a good time to evaluate the piston and replace if on or near the margin. The crank/rod are typically pretty solid. If you don't see any bronze-like material in the oil filter and the crank doesn't have any up/down play and is in spec laterally then I'd run with it for now.
    Ken
