CRF150r output shaft seal replacement
  • mitchmech
    by mitchmech » Sat Sep 23, 2017 2:38 pm
    My son has a CRF150r which is leaking oil from the output shaft seal behind the front sprocket. Can I change that seal without opening up the engine? Any help is appreciated!
    Re: CRF150r output shaft seal replacement
    by Back2-2 » Sat Sep 23, 2017 7:52 pm
    You should be able to remove the sprocket and lever the seal out. Installing the new seal will require a PVC home made driver to go over the spline shaft and drive the new seal in. Easy to do. :)
  • mitchmech
    by mitchmech » Wed Jan 31, 2018 7:22 pm
    Thank you, that worked great!!
