08 CRF250r and 06 CRF230 oil
  • LeighRoy1014
    by LeighRoy1014 » Tue Jul 25, 2017 5:40 am
    Hi all,
    I'm currently riding a 2008 Honda CRF250r and my girlfriend is on 2006 Honda CRF230. My question is: Can we use the same engine oil in both bikes? This will ease maintenance cost and time.
    The CRF250r uses SAE 10W-30 and (according to the service manual) the CRF230 can use anything from a SAE 20W-50 to a 10W-30 dependent on the temperature range.
    I'm based in South Africa and cold winter mornings, when riding typically starts, is about 15C and warm summers days could range to 36+C.
    Any ideas?
    Regards
    Re: 08 CRF250r and 06 CRF230 oil
    by JimDirt » Tue Jul 25, 2017 9:12 am
    As long as the oil is a API Service Classification of "SG" , which seems to be required of both bikes , you should be fine , that is the only classification i see to be concerned about with the exception of it meeting the JASO-MA requirements for a Wet Clutch , which i would guess your oil is , ....so basically , you should be fine using the same oil for both bikes......... ;)
