The JD Jetting kit is the best jetting/needle combination we have tested. This kit along with the fuel screw will get your jetting dialed in. However, you can also have other issues with the carb affecting the idle. You should also replace the floating valve seal.Will the JD jetting kit help with idle problems. We've replaced the pilot jet all the way to a 45. Still doesn't want to idle
