02 side case same as 04?
    momuzik
    by momuzik » Wed Feb 15, 2017 8:54 pm
    Does anyone know if the the 02 crf450r sidecase that houses the waterpump will fit on an 04?
    by Old Dude » Wed Feb 15, 2017 10:06 pm
    Using the Yeltrik Motorsports OEM parts finder accessable here thru CRFsOnly it shows that the part numbers are the same... 11331-MEB-770. You might double check that...my wife has claimed I have been wrong in the past.
    momuzik
    by momuzik » Thu Feb 16, 2017 12:54 am
    Ok super thanks OD for your help
    by JimDirt » Thu Feb 16, 2017 11:28 am
    As OldDude mentioned , it "should" be the same , it should be 02-04 with the same case , the only other major differences between 02-04 would be , the forks (mainly size of compression valving stack piston and outer tube length ,rebound rod and valving is the same) , frame (mainly mounting points for muffler/header mid-pipe mount) , flywheel (weight of flywheel) ,rear suspension linkage (02 dogbone different length ,03-04 the same) , Airbox and filter (02 filter only fits 02 airbox , 03-04 are the same) ,swingarm the same 02-04
    Those are just off the top of my head , but that should help you a little with some decisions
    momuzik
    by momuzik » Thu Feb 16, 2017 11:31 am
    Ok thanks Jim that helps alot much appreciated
