Where is the engine oil going?
  • Dlgarus
    by Dlgarus » Tue Jan 17, 2017 6:43 pm
    I change the engine oil in my 05 250x every 10 hrs. I add the recommended 690 cc and for some reason it never reaches a visible level on the dipstick. I can see the oil level with a flashlight and it is definitely lower than the dipstick. The bike runs great and I don't usually check the oil level because of the frequent oil changes but I'd love to know where it is going.
    Thanks for your help.
    by JimDirt » Sat Jan 28, 2017 6:33 pm
    Few questions
    Are you sure the bike is level when checking ?? , this could have a effect on the reading
    Are you changing the filter ?? , if not , did you tilt the engine to the clutch side a little first to make sure the missing oil is not hiding in the filter area ??
    Are you noticing the oil level dropping ??? , if so , check the transmission side to see if the oil is migrating to that side of the engine , it could be a right side crank seal leaking
