06 steam/overheating after new pump
  • jh300zxtt
    by jh300zxtt » Fri Mar 25, 2016 10:10 am
    Hey, recently did a little bit of work to my 06. New water pump seals/bearings, new balance shaft seals/bearings, valve adjustment and tore apart the carb and cleaned everything. As soon as I got it back together it started no problems. After about 30 seconds i noticed some steam coming from the exhaust and rad cap. Shut it off, checked everything, looked good, started it back up. This time there was a erractic pinging noise that sounds like its coming from the top end to go along with the steam. No coolant or oil is coming from the weep hole, double checked pilot jet settings. Dont know where to start on this one. Any ideas?
    by JimDirt » Fri Mar 25, 2016 11:54 am
    It sounds like you have air in the system , it needs to be "burped/bled" of air , its a closed system similar to your car , you should get fluid from the drain hole (the bottom water pump bolt with the brass washer)
    (sometimes you won't get fluid when the engine is off unless you loosen the radiator cap to break the vacuum)
    Make sure the radiator is full , then start it and let it idle (only for a minute or so) , while its idling , crack the drain bolt on the water pump cover loose , and you should get some air , then fluid , when you get a lot of fluid , shut the bike down , let it cool for a few , then pop the radiator cap and top off the rad , then repeat , it should start flowing fluid from the bolt (just slightly loose , don't remove it) , what you are doing is bleeding the system just like your bleeding brakes , try that and see if it fixes the issue , and report back
  • jh300zxtt
    by jh300zxtt » Fri Mar 25, 2016 4:23 pm
    Thanks for the input. I'll give it a shot after the holiday weekend and see if it helps
Users browsing this forum: No registered users and 12 guests
