05 crf70 carb choke plate
  • ejhjul
    by ejhjul » Thu Mar 17, 2016 10:38 pm
    Question regarding choke plate. Tore down carb for cleaning after sitting for ?? years.
    Removed choke assy, and smal tension spring came off shaft. Put back together as best I could figure.
    Question is this. When choke is on (in up position) the choke plate shaft turns to seal choke plate against carb body.
    When choke is off, choke plate still rests against carb body, but will move against spring tension if pushed. With engine running is the air being pulled through carb enough to move choke plate open against the spring tension.
    Or could I still have installed wrong. Sorry no pics yet.
    Bike starts w or w/o choke, and responds to all throttle positions. Dumps fuel from overflow cause seat is still dirty I think.
    Can kind of get to idle on its own.
    FS at 1 1/2 turns out, idle screw seems to have no effect, and have not gotten throttle cable adjusted spot on just yet.
    Any thoughts would help, unsure about that small spring. Thanks Again.
