Hi
I am having an issue with my speedometer on the bike that shows less speed then normal by 10+ kmh.
Does anyone knows the way to configure this speedometer?
Or should i change it to get a new one?
Thank You
JimDirt wrote:Welcome to the site !!
Did you get a manual with the bike ?? , and have you checked with the dealer ??
The Euro bikes are completely different than the U.S. models , so unless someone from over there is watching these forums , its kind of hard for anyone to give you a exact answer
I would guess that it is digital and there are menu's to look thru , on Digital speedo's here you would measure the runout of the wheel , by marking the tire sidewall and the floor so the marks are the same , and rolling the tire 1 full revolution across the floor , then mark the floor where the mark you put on the tire is even with the floor again , measure the distance between the 2 marks on the floor , and use this number for your wheel size , there should be a setting in the munu to enter the tire size , once you do that , you "set" the info , and exit the menu , then ride the bike and see if the speedo is accurate
Hope that helped some !!
