Linkage bearing replacement
  • mikezim
    by mikezim » Tue Feb 16, 2016 1:02 pm
    Hi guy. Quick question - trying to replace the linkage bearings on my 450x.
    With the triangle - are all the bearings able to be pressed out? Or is there a lip separating the 2 bearings? (there is a single bearing at the front - then 2 bearings on either base of the triangle.
    Thanks
    by JimDirt » Tue Feb 16, 2016 2:16 pm
    Yes the bearings just press out
  • mikezim
    by mikezim » Tue Feb 16, 2016 2:32 pm
    JimDirt wrote:Welcome to the site !! \:D/
    awesome thanks. Just was wondering cause these things seem to be welded in there. Super hard to press them out. Gonna use a vice in the morning.
    by JimDirt » Tue Feb 16, 2016 4:28 pm
    Yea sometimes those things are hard to get to budge , once you get a little movement out of it , it should go , you might try lightly heating the knuckle and then trying to press it out
    by Back2-2 » Fri Feb 19, 2016 7:39 am
    Penetrating oil - give it time to work. Works wonders. :D
    by crfsonly » Fri Feb 19, 2016 8:32 am
    Here's a CRF's Only How-To that might help as well:
    http://crfsonly.com/howto/450x/shock-li ... eplace.php
    Ken
