450r -450x parts compatability
  • lmau28
    by lmau28 » Mon Sep 21, 2015 7:15 pm
    hi guys
    just got a query in regards to some parts for the 450x. i currently have a 2007 450r and looking to buy a 450x. the 450r has a boyesen water pump, R&D powerbowl with JD jetting and a cam. now, can i swap over the bowl etc and water pump? i think from what i have gathered i will be able to swap the stock 07 cam over. Any help would be appreciated Cheers
    by JimDirt » Wed Sep 23, 2015 8:12 pm
    As far as i know everything should be the same , i know for a fact the carb bowl and jet kit will swap directly , the cam needs to have the same de-compressor setup as the other , otherwise you will have to swap the cam tower as well along with the cam
    You can PM Ken ( crfsonly owner ) and he can give you the details on the cam (and water pump) http://www.crfsonly.com/forum/profile.p ... rofile&u=3
    Re: 450r -450x parts compatability
    by crfsonly » Thu Sep 24, 2015 10:01 am
    lmau28 wrote:hi guys
    Boyesen water pump - No
    R&D Powerbowl - Yes
    JD Jetting - Not really. Needles are different
    Cam - Depends on the year of the 450X you end up with whether it's a direct cam only swap.
    Ken
    crazybrother
    by crazybrother » Thu Sep 24, 2015 11:05 pm
    2007 450R cam will fit the 450x. You will just need to remove the old decomp. setup (450x) if it's the older style. They both use the same cam carrier. Make sure that you swap over the entire cam from the 2007 450R.
    My post from a couple of years ago...
    http://www.crfsonly.com/forum/viewtopic ... highlight=
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
  • lmau28
    by lmau28 » Tue Oct 06, 2015 3:40 am
    thanks guys for the info. gives me a starting point for it.
    cheers
