To start with bike specs
2006 450X
4000'-7000' MSL riding altitute
New carb parts...
needle jet, floating valve, float needle, o-ring kit, pilot jet, R&D mixture screw
Here is the deal, over the past 3-4 months my bike has been progressively getting harder and harder to start(when hot) and getting worse and worse gas mileage. It is impossible to get my idle mixture set properly as well. It started by actually having to use the hot start at first. I Never had to use it in 2 years of riding this bike, so I thought that was weird. Then it got to where I would have to roll it down a hill to get it started. Then it just stranded me a few times in the middle of no where and wouldn't start doing EVERYTHING. But then the next day after sitting all night it would fire right up like nothing was wrong. The valves are spot on to start with. So far I have tried brand new 42, 45,& 48 pilot jets, all three do the same thing. At low idle I can turn them all the way in and the bike doesn't die, it just raises the idle once it's turned all the way in. I have checked for leaks around the carb boot from the carb to the intake manifold, I have removed my hot start plunger, cleaned it, lubed it. It is working well and not sticking. I have replaced the floating valve and double checked to make sure it was installed in the proper way. I have changed the needle jet or emulsion tube what ever you prefer to call it. I have changed the float needle and verified the float level with the manual. I have checked for cracks around the rubber boots as well as cracks on the hot start plastic nut. The carb has a brand new o-ring kit and I have verified it has a good seal at the top of the carb in case for air leaks.
BUUUUUUUT....I still can not get it to start good. Once it's running it runs like a champ, but I can not get the idle mixture set so it starts all the time. I have used the hot start lever and that helps sometimes, but not every time. it's inconsistent. I started with the stock brand new 45 pilot jet, set the idle speed at 1200-1300 rpms, turned the brand new R&D mixture screw all the way in and it died the first time with 1 turn to go. So I turned it out the 1 1/4 turns, couldn't get it started, so I turned it out 3 full turns from all the way in, and it would start good. So, it jumped it up to the 48 pilot jet because it was more than 2 1/2 turns. Finally after a TON of cranking and hot start I got it to start. I set the idle again at 12-1300 and turned it all the way in and it never died, it just raised the idle speed once it was turned all the way in, so then I said screw it, i'm gonna see if the 45 works any better again, but then the second time I could screw the mixture screw all the way in and it wouln't die, so i put the 42 in and I could also screw that one in all the way and the idle would raise up once it was screwed all the way in too. I am at a lose. i've been working on this for weeks, have spend over $150 on this carb in the last few months and it still isn't working!
