Looking to buy 2004 crf250r PLEASE Read
  • Wioffroader
    by Wioffroader » Wed Jul 01, 2015 1:21 pm
    In a couple days I am going to look at a 2004 crf250r. I was wondering what to look for when I go to look at it. I am most likely going to use it as a trail bike. So what should I look for? I don't want to get it home and have to dismantle the whole thing. Thanks!
    by JimDirt » Wed Jul 01, 2015 6:14 pm
    Most common is to look for excessive wear , if the seller claims low hours , then the coating on the clutch and ignition covers should not be worn thru , if its heavily worn , then expect the bike to have a lot of time on it
    Next would be to look for obvious signs of neglect , like excessive dirt covered in oil , this is a sign of either lack of maintenance or just poor upkeep , which means things will be worn out or on their last leg
    Turn the bars and feel if it feels chunky/notchy , if it does then that means it is in need of Steering Head Bearings , not a biggie , just part of normal wear and tear , but its a added expense that should be considered at time of purchase to be included in the cost by way of a price break , this goes for anything that "needs replacing" , including tires , since tires are now in the $200 neighborhood for a front and rear Dunlap , again , a factor as to the asking price
    Mainly look for neglect and claims that cant be backed up with receipts , if the owner is not producing receipts for claimed service or repairs , chances are he is not being honest and you could be getting a major repair bill in either parts and/or labor to get the bike up to standards
    I am sure others here have suggestions as well that i have forgotten to mention
    Hope that helped some ;)
  • Wioffroader
    by Wioffroader » Fri Jul 03, 2015 5:11 pm
    Awesome thanks looked for all that and made the purchase 😄
    by JimDirt » Fri Jul 03, 2015 9:57 pm
    Great , hope you have good luck with it and enjoy the riding !!
  • Wioffroader
    by Wioffroader » Sat Jul 04, 2015 9:08 pm
    JimDirt wrote:Great , hope you have good luck with it and enjoy the riding !!
    I am enjoying it. The only thing I would like to do is make the suspension softer. Seems really stiff. What is the correct procedure to softening the suspension?
    by JimDirt » Sat Jul 04, 2015 9:17 pm
    If its sprung for your weight , then your going to need to revalve it , if you can't get what your looking for out of the clickers, this is the only option , other than finding some 250X forks and shock and slap them on , the stiffness is caused by a few things , the valving is stiffer on a R because the intended purpose is for MX , not trails , the other issue is the fork tubes themselves are physically stiffer , so that transfers back to the rider
    So you have
    Proper Springs for your weight/skill
    Clicker Adjustments (Compression Clickers: counterclockwise is softer , clockwise is stiffer
    Valving
    Fork Tubes
