Old Dude wrote:I used Baja Designs lights and just drilled into the headlight shell and license plate mount on one project. On another build I used Tusk Racing stalk (or stem) mounted lights but supported them with a modified metal conduit connector. Aluminum or thin walled tubing will work as well. Cut the tubing to the appropriate length and slip it over the"flexible stalk" I then used a flat washer on the inboard side (outside surface of the license plate/tailight mount) and one on the inside between the lock washer and plastic.
