Welcome to the site !!
13/51 should be fine for the occasional street use , i am geared 13/52 (lower than yours) and can easily do 75+ without getting near the limiter , i would check the speedo setting in the Trail Tech , go thru the menu and check the numbers , i am guessing your wheel size number should be around "2197" , to verify this ,
On a flat surface , mark the tire sidewall and the ground with a marking pen
Roll the wheel until the mark on the wheel completes 1 revolution and is in the same position as started , mark the ground here
Measure the distance between the marks in Millimeters , take that measurement(you can multiply inches by 25.4 to convert to mm if you don't have a tape that measures in mm)
Use this number for your wheel size (it should be between 2110 to 2200 or so) *i am guessing around 2197 give or take is where you will end up depending on tire brand , air pressure etc*
To check the Trail Tech for the tire size:
Hold the 3 buttons down at the same time to get to the setup menu (hold for 3 at least seconds)
Next go thru the menu (Mode button) , it should be Distance Units first (it will say Units in the lower right corner) , this should be set to M/H , if not press left button till it does , then press MODE , it will move to next setting , this should be Wheel Size , default should be 2110 , to change the numbers , Left Button to modify number , Right Button to go to the next number in line , to confirm setting is Mode
Once you are done just cycle thru the rest of the menu's till it goes back to normal mode (Mode button), OR , let the Trail Tech sit a few minutes and it will go back to normal mode and shut down on its own
Hope this helps !!!
