What is the right way to preform a leak down test
  • flatop016
    by flatop016 » Sun May 24, 2015 6:11 pm
    What is the right way to preform a leak down test and compression test on a 08 crf 450r
    by JimDirt » Sun May 24, 2015 8:05 pm
    Leakdown is done with the engine on Top Dead Center , Compression Stroke 100psi at gauge , if air is heard thru Intake , then Intake Valves , if heard thru Exhaust , then Exhaust Valves , if thru Crankcase , then Rings , if thru Radiator then Head Gasket
    5% leakage is about all i would accept at absolute most for a issue to be concerned about , obviously anything more would mean mandatory tear down , optimal would be 0%
    This is the procedure for the Compression Test
Users browsing this forum: No registered users and 13 guests
