Rod same length as updated ac pump kit?
  • SandySketch
    by SandySketch » Sat Apr 25, 2015 2:13 pm
    I'm installing an updated acc pump kit right now in my 06 CRF450R. The rod that is supposed to be longer is the same length as the one that came out. The original diaphragm looks stock with the longer pin. Confused, do I continue, or is something wrong.
    Thanks,
  • gomercrf450
    by gomercrf450 » Mon Jun 01, 2015 1:20 pm
    what did you come up with on this i just ordered the same kit for my 2003
  • tanJ
    by tanJ » Thu Aug 06, 2015 2:41 pm
    Interested as well. I just updated mine with the kit and the rod was the same length.
    by crfsonly » Mon Aug 10, 2015 10:53 am
    Continue with your installation. Use the new rod even if it is the same length. We've seen different rod lengths in some models and it's been inconsistent as to which may or may not have the longer rod. Make absolutely sure you install the new diaphragm as it has a shorter pin so it will have a longer duration.
    Ken
