Anyone with a Rekluse Core Exp that doesn't chatter/squeal?
    Four-Fifty-X
    by Four-Fifty-X » Sun Mar 08, 2015 8:38 pm
    I just installed a Core Exp 3.0 on my X. Had my first ride with it today. Overall, it's awesome--it definitely helps me ride better.
    It has an annoyance thought--it chatters/squeals at take off from 1st or 2nd. It's not horrible, but I don't think I can get used to it.
    I did a bit of research and it seems to be a fairly common behavior. It most cases Rekluse says it's normal, and that their clutch basket will correct it.
    Well...I just spent $900 on a clutch, now I need to spend another $300 so that it doesn't make scary sounds?
    Anyway, do they all do this when running with a stock basket (which by the way is not notched at all)?
  • hr6910
    by hr6910 » Mon Apr 20, 2015 7:28 pm
    I just installed a rekluse in my 2005 450x and have the same chattering problem. I have been told that changing the transmission fluid to Maxima 80w transmission fluid helps a lot. Haven't tried it yet, but I plan to.
    Good luck!
  • Kap
    by Kap » Mon Apr 27, 2015 6:43 am
    I have an old Rekluse that did that. There was some adjustments made that corrected it. Stiffer springs I think. It's silent now. It was not engaging properly at take off.
    06 CRF450X Rekluse with hand brake.
    CR500AF Rekluse rear hand brake.
    Four-Fifty-X
    by Four-Fifty-X » Thu Jun 11, 2015 7:05 am
    Thanks guys. I'll give the maxima a try this weekend.
