stevendavis wrote:I'm changing my front fork springs to .49's and thought I'd also try 10wt oil. I'm not opening up the inner tube at all. Is it ok to leave the 5wt oil in the inner tube and use 10wt on the outer tube with the new .49kg springs? Thanks.
stevendavis wrote:
Also, does any one know if the 07 is the SSF fork? I"m looking at getting one of these:
http://www.ebay.com/itm/171395968006?_t ... EBIDX%3AIT
riddler9 wrote:okay, kept scrolling through the images from the search that you provide and found this:
It looks like it should work.?.?.? I would still be concerned about putting things back together. The normal cap wrench is very thin but still poses a challenge when working directly under the bars.
riddler9 wrote:Why not change the cartridge at the same time? The oil is definetly broken down just on time alone. Throw in all the heat from the fork usage and...
