Fork problem
  • upyourkiltbatman
    Fork problem
    by upyourkiltbatman » Mon Dec 22, 2014 5:01 pm
    Went out on the bike this weekend and noticed the bikes front end was al over the place , stopped the bike and found that the first bit of the stroke is almost solid . Then it will go a bit but stiff , only changed the brake pads since I last went out so not sure what's going on ?
  • ANYTHNGFAST
    by ANYTHNGFAST » Mon Dec 22, 2014 9:27 pm
    Do you have fork bleeders?
  • upyourkiltbatman
    by upyourkiltbatman » Tue Dec 23, 2014 1:52 pm
    Yes but it's not that I bleed them all the time .
    riddler9
    by riddler9 » Thu Dec 25, 2014 10:02 pm
    Check to make sure the front wheel is aligned properly in the fork - it will cause biding if not - most likely what the issue is. Loosen the right side axle pinch bolts, pull in the front brake and pump the forks a few times, then re-torque the ping bolts.
    When was the last time you changed the fork oil - including the inner chamber?
    Official Lurker
