rear wheel ass-embly
  • datan556
    by datan556 » Fri Aug 15, 2014 12:29 pm
    Gday
    Took the rear wheel off cause i thought it wasnt turning freely. So thought was take it off, check bearings and grease her up. Done all.and now shes not turning anywhere. Now more restricted than bwfore. Any help on this one chaps? Wtf did i do wrong. Have had many dirt bikes but this has never happened. Chain all good and bearings
    Thanks for helping
    by JimDirt » Fri Aug 15, 2014 6:55 pm
    Does the axle slide in and out freely with the wheel off and with the wheel on ??
    Is the center tube (where the axle slides thru) binding/cocked slightly and putting pressure on the axle ?? , you might have to loosen everything up and install the axle to check to make sure its not bound and causing the issue
  • MX_RACER1
    by MX_RACER1 » Mon Aug 18, 2014 7:24 am
    Jim Dirt has a good suggestion. Also try moving the wheel with the chain off. This eliminates a chain binding scenario.
    Loosen the axle nut but don't take it all the way off. Can you slide the axle freely? Does the wheel now spin? It is possible to over tighten and bind the rear assembly.
    Hope it helps !!
