2006 250x — Transmission oil crossing over into crankcase oi
  • TonkaRider
    by TonkaRider » Wed May 21, 2014 5:05 am
    I have read posts that describe my problem exactly. Transmission oil crossing over into the crankcase, level in trans gets lower and crankcase gets higher. From this I am drawing a logical conclusion from the information in the posts that my problem may be the reed valve inside the crank case.
    Yet, I read some conflicting information in the posts that indicate the reed valve is possibly not the issue but that it may be the balancer shaft(?) and/or crankshaft seal.
    Before splitting the case and pulling everything apart I was hoping to get a little more clarity on the issue to pinpoint all the parts I should replace while in there.
    Your insights and knowledge are much appreciated!
    Thank you in advance.
  • TonkaRider
    by TonkaRider » Fri Jun 20, 2014 1:54 pm
    I went in and replaced the reed valve, and all the oil seals, oil still crosses over to crank case, any ideas as to what I may have missed?
    Thank you in advance!
    by crfsonly » Wed Jun 25, 2014 9:23 am
    likely culprit is a crank seal.
