Does a 2005 CRF150F have a cam chain tensioner?
  • brian-crf150f
    by brian-crf150f » Tue May 06, 2014 3:08 pm
    If so, could it be causing a rattle sound cause it's loose?
    Video of rattle sound...
    http://youtu.be/8za8yYxr27I
    Thanks for the help!
  • brian-crf150f
    by brian-crf150f » Wed May 07, 2014 8:49 am
    Anyone?
    by crfsonly » Wed May 07, 2014 4:23 pm
    yes...it does have a cam chain tensioner. it could be the source.
    riddler9
    by riddler9 » Wed May 07, 2014 4:24 pm
    It has one - it is on the cylinder. Part number 14520-KCT-692
    The tensioner mechanism would likely not rattle unless it had a catastrophic failure, in which case you would have much larger noises :D
    If you have cam chain noise, it could be the tensioner does not have enough pressure on it, the guides are worn, or the chain is stretched (or any combination of).
    Official Lurker
  • brian-crf150f
    by brian-crf150f » Wed May 07, 2014 5:18 pm
    Well...it doesn't seem to be catastrophic as of yet, the bike starts first or second kick and has a steady idle. It just started this rattle noise a couple days ago...and I wanted to make sure whatever it is is taken care of before a catastrophic failure occurs.
    I've been reading that these factory automatic tensioners "LIFTER ASSY., TENSIONER - 14520-KCT-692" are prone to failure...after so many miles. Some sites are selling manual cam chain tensioners, like the "Tokyomods Camchain Tensioner CRF150F"
    “THIS ITEM REPLACES OEM TENSIONERS THAT ARE PROBLEMATIC AT HIGH RPMs.”
    http://www.ebay.com/itm/03-05-HONDA-CRF ... e0&vxp=mtr
    So I was trying to find out if anyone else that owns a crf150f might have had this issue on the message board. Problematic "auto" tensioner not applying enough pressure on the cam chain. I've seen other videos of crf's that had this rattle sound...but no resolutions.
