Patrik wrote:Thanks for your answer.
I will try this
But if the headgasket is blown up, the water would be in the engineoil ?
Or am i wrong
Sorry i misunderstood your accent
, i was thinking you meant Engine side .... my bad .... then yes , as Aussiecrf230 said , it has to be in the water pump somewhere
I would think a Steam Cleaner rather than just a pressure washer would make the oil milky , because i pressure wash my bikes after every ride with my 2750 psi pressure washer , and have never had milky oil , and it would dissipate if it were just condensation , the moisture has to be a large amount to keep the oil milky so you need to be looking for a way for the water to enter the tranny , which will either be a opening somewhere with a bad O-Ring or gasket , or the Water Pump seal
Also if engine oil and tranny oil were mixing, then either your engine side or tranny side would be overfull and the other would be low
