Will '03 White Bros Exhaust fit an '02?
  • blackedout96
    by blackedout96 » Fri Apr 18, 2014 3:35 am
    Having a hard time finding an exhaust for my '02 and really want to avoid new. There's a full white bros system on ebay, but it's off of an '03. Anyone know if this will fit?
    Sorry I know this topic has been beat to death on every dirt bike forum in existence.... I just couldn't find info on the interchange between these two years.
    by JimDirt » Fri Apr 18, 2014 7:05 am
    I am not 100% sure , but i think 02 is by itself , it has to do with the mid mount location being different , since the subframe is different on the 02 from 03-04 , so my best guess is no it wont fot , it has to be for a 02 to fit without re-welding the mount on the subframe , i believe clearance wise going from front to back it should be about the same , just the mid mount , i guess you could get a 03 subframe , it is about 10mm lower on seat height , but it should bolt up , but you will need the subframe and airbox for the 03 as they changed it
    That is the issue with the 02 its all by itself on a lot of things , i just took the stock muffler , put a Pro Moto Billet endcap on it and cut 3" off the end of the muffler (the same size as the 05) which gets rid of the muffler hanging off the back as far as it does stock
  • blackedout96
    by blackedout96 » Fri Apr 18, 2014 3:42 pm
    Yeah that's what I was afraid of. I can't find anything at all for it, stock or aftermarket. Bought it with no exhaust and just need to find something. Rather not spend $400 on a new one.
    by JimDirt » Fri Apr 18, 2014 7:03 pm
