I did the pink wire even after being told it would not change anything on the '09. It did not change anything
You can eliminate the airbox as an issue by taking the door off and riding it. If it goes away then cut-away.
If it is running well except a bog/hesitation on the bottom then I would guess it is the adjustment on the leak jet or you need to drop to a 42. The leak jet is not something that can be adjusted on the stand; you really need to take the bike out and nail the throttle creating a load to dial it in (you may already be doing this).
If you have more than just hesitation on the bottom-- slightly hanging idle, flat spot in the power band, etc. -- regardless of how small, then I would check the common stuff that can go wrong on a carb rebuild: make sure the o-ring for the fuel screw went in straight, throttle plate gasket is on in the correct orientation and not warped, diaphragm is no upside down.
