Thanks guys. I finally got it. Pulled the carb and got it onto a table. The pin had a head on it that looked like a socket head, but instead of a hex socket it is just round. The pin just blocks access to the screw so it's presence is strictly for tamper proofing.
The pin head was like half way in an easement in the carb casting so ther was no way to actually grab the head of the pin. As the centre of the pin head was hollowed out I could use a needle nose vise grip and grip the head between the hollow and the outside edge. A wiggle and some not too agressive pulling and it popped out like a rotten tooth. The fuel screw was still well inside the hole so I pulled the bowl off an foun it was still not where I could get a hold of it. It had a 'D' shaped head so I used the red crimp connector trick and finally got it out. Needed 2 connectors, messed the first one up after a couple of turns.
The R&D screw went right in the hole after I got the spring, washer and o-ring out. I jetted the carb according to what the JD kit recommended and began to reinstall the carb. After swearing a lot at the hot start nut I finally got the carb in.
I understand the need for Honda to make these things tamper resistant, but holy crap, I think if someone had an angled needle nose vies grip this could probably have been removed with the carb on the bike, but getting the factory screw out with it so far up inside the carb, would have taken some doing.
If anyone is interested I can take some pics of the part I removed. I was going to take some pics as I was doing it but my phone died
It's just the luck I've been having.
For Kyle, it's a 2013. Manufactured 08/12. Got it new in the box a month ago or so. It was a left over from last year's stock.
The dealer and the dealer techs had no idea what I was talking about. They had a used 250x, I think a 2012, and it had the same POS pin thing in it. Maybe it's a Canadian version thing or something. Odd that the techs are clueless, but that's been my experience with that particular dealer. We only have one dealer in town so I guess I'm stuck with them. I would never buy a street bike from them, and had my VTX1800 serviced there once. The service department is incompetent at best so I'm not surprised they know nothing. Sorry, I feel better now.
