Runs great but 5 turns out on pilot
  • jmudweiser
    by jmudweiser » Thu Mar 06, 2014 11:34 am
    2006 crf250r, carb has been dipped, all new jd jet and leak jet kit. all new orings including the mid body. New exhaust gaskets etc. I am using a flex jet pilot screw. we have a 42 pilot jet, 175 main jet and the red jd needle set at the recommended clip setting for sea level to 1000'.
    the leak jet is a 45, stock was 55.valves were all replaced recently also.
    Now with all that in mind,it had lean popped on decel and ran so hot the pipes melted 2 air boxes until I started running it 5 turns out. I replaced the airbox and put the 45 leak jet in. Bike runs awesome, great response no popping, pulls hard,,, just is 5 turns out. should i up the pilot?
    by Aussiecrf230 » Thu Mar 06, 2014 11:04 pm
    Yep bigger pilot would help.
    Check the jetting sticky for what others here found works for them.
  • hall_philip
    by hall_philip » Fri Mar 07, 2014 6:27 pm
    I would go for a 45 pilot first. that should do the trick. im about the same elevation and ride in 90 deg. avg. in the summer
    by crfsonly » Sun Mar 09, 2014 3:50 pm
    definitely go up on the pilot. you should be under three turns out.
