daughter changed her own oil but pulled the wrong bolt out.
  • hall_philip
    by hall_philip » Sat Jan 18, 2014 10:37 am
    my daughter is six and wanted to change her own oil, I thought WOW how great!! well she did good on the part of grabbing the right tool for the job, but she had pulled the other bolt on the bottom of the crankcase on her 2003 xr 50. is this going to affect anything if I just screw it back in or does it have anything to do with the kick starter? I only question it because on my old 200x trike there is a bolt that locks the kick starter spring hammer into place and if you pull it out it will rotate allowing it to ride on top if 3rd gear, thus causing severe trans work that I would rather not fix right now. any help would be much welcomed.
  • hall_philip
    problem solved!!!
    by hall_philip » Sat Jan 18, 2014 11:23 am
    it was just to the cam chain ten. bolt. no biggie.
