Pressure found when changing oil
    shaff
    by shaff » Fri Jan 17, 2014 12:55 am
    I recently crashed pretty good and since then when I've changed my oil I've found some pressure build up. The first change it didn't really register but yesterday I pulled the fill plug first and had a hissing noise as I took the cap off. I'm doing the normal warm up the bike first and when I pulled the plug that's when I noticed it. Any thoughts?
    crazybrother
    by crazybrother » Fri Jan 17, 2014 1:10 pm
    Check your crankcase vent tube. It comes off the top of the Cam Cover and goes to your airbox and there is a drain below the carb.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
    shaff
    by shaff » Fri Jan 17, 2014 3:20 pm
    crazybrother wrote:Check your crankcase vent tube. It comes off the top of the Cam Cover and goes to your airbox and there is a drain below the carb.
    Winner winner chicken dinner! Thanks!
