random piece of metal in the stator.
  • blackj
    by blackj » Fri Oct 11, 2013 11:34 pm
    I found this between my stator and flywheel, its cut a groove out of both on them.
    I have replacement parts but before I put the bike back together I'd like to know where this thing came from ?
    Thanks
    gal8x
    by gal8x » Sat Oct 12, 2013 1:22 pm
    That looks like it belongs to a wiring harness. Just a guess.
    What bike did it come from?
    2005 CRF450X (plated)
  • blackj
    by blackj » Sat Oct 12, 2013 1:35 pm
    2005 crf250r.
    Yes it looks like it should be holding something .
    I figured I'd ask more knowledge people
  • bdl507
    by bdl507 » Sat Oct 26, 2013 12:34 pm
    Looks like part of a bearing cage to me I would investigate that more.
  • blackj
    by blackj » Mon Oct 28, 2013 1:25 pm
    It was piece of the camshaft bearing on the right side.
    It must have broke off and traveled down the timing change space.
    I think I have found any pieces but is there a way a piece could get from the head into the right crank case?
    Thanks
    by crfsonly » Wed Oct 30, 2013 2:42 pm
    check the back of the flywheel and in the left side case cover. if pieces end up in your cam chain it will be a bad bad day for you.
  • blackj
    by blackj » Wed Oct 30, 2013 2:50 pm
    the piece I found had already made its way in between the flywheel and stator. Chewed up the stator pretty badly as I discovered when I removed the left cover. I drained the oil from that side and cleaned out any remaining oil. I plan on putting a new oil filter and some cheaper oil in and run it for a while and then drain it again. to make sure I got everything.
    But I haven't removed the right crankcase cover as I don't see how any pieces would make there way in there. Please correct me if I'm wrong.
    thanks
    by crfsonly » Wed Oct 30, 2013 2:52 pm
    meant to type "left". corrected now.
  • blackj
    by blackj » Wed Oct 30, 2013 2:55 pm
    cool.
    I really didnt fancy having to add the right side cover to my to do list
