TJohn wrote:Your going to have to take off the right engine cover, and obviously the water pump cover. the bearings pressed into the inside of the engine cover. They use those blind bearing pullers to remove that. and a seal is on that side too i believe. The impeller shaft may need replaced too if seal wore groves in it. Pretty easy job once in there.
