JimDirt wrote:Have you looked at your fluid levels since this happened ??
If so is one side overfilled and/or the other low ??
Has it done it since that 1 time ??
Back2-2 wrote:It is very likely from the breather tube off the valve cover. Condensation / oil vent mix.
The tube runs from the top of the valve cover, tee's into the gear case vent then over to he air box and down to the rear of the engine & pops out near the rear linkage. Stock it has a plug so the fluid builds up. Many people open the tube to allow drainage / breather out the tube end.
You also have a air box drain port that can drip oil if the filter gets a little too much oil when cleaning & oiling. It builds up and pools in the bottom of the air box & drips out on to the swingarm / suspension area.
Take a good look & trace it out.
indianFighter wrote:JimDirt wrote:Have you looked at your fluid levels since this happened ??
I checked and topped up; the clutch side used up about half a litre, the engine oil was fine. Haven't started the bike since then but standing still there is no leak anywhere, it just happened that one time when the engine got really hot.
What did you mean by one side overfilled?
Back2-2 wrote:Mr. Jim, he stated the engine side was fine which shows that the shortage of the trans side did not migrate to the engine side.
I suspect he was banging those sharp, heavy leaning turns and spit trans oil out the gear case vent tube.
what do you think ?
That's one ugly pile of engine you have there !~ Ouch...
