No Spark
  • Finn
    No Spark
    by Finn » Tue Aug 06, 2013 1:52 pm
    Hi,
    I have no spark in my 08 250r, im not the best with wiring so im asking for advice, I know I have no spark but don't know why. So far I have checked the basics, all connections and the kill switch which are all ok. I know I need to check the coil but don't know the resistance values and how do I check for power from the stator?
    Any help would be appreciated, Thanks.
    by JimDirt » Wed Aug 07, 2013 10:14 am
    I take it you dont have a Honda Service Manual ?? , if not , all the values will be in there , the first "tool" you need when working on these bikes is the Honda Service Manual , they are between $45-$65 depending on what your Honda Dealer charges , you can look on EBay , you can sometimes find them for $30-$40 , get the Service Manual , not the Owners Manual , it will have any info you need and will give detailed instructions usually with pictures to guide you thru electrical troubleshooting
    It will be much easier on you with the manual in front of you then someone trying to explain it to you step by step
