AC PUMP WONT WORK.
    OLDFATGUY
    AC PUMP WONT WORK.
    by OLDFATGUY » Tue Jul 02, 2013 1:08 pm
    Ok, took the carb apart for a buddy of mine, ktm450. put in new pump diaphram, o rings gaskets, sonic cleaned whole carb. AC pump wont squirt. tube passage seems clear, any ideas? thx, d
    by JimDirt » Tue Jul 02, 2013 4:25 pm
    Diaphragm upside down ???
    crazybrother
    by crazybrother » Tue Jul 02, 2013 9:06 pm
    Are you sure that the passage is clear??
    Make sure, blow some air through it, then some degreaser to make sure.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
    by crfsonly » Wed Jul 03, 2013 2:28 pm
    to add what has been mentioned, also make sure fuel is getting to the AP. i have seen a couple of check valves either not functioning or clogged. if he's done any work to the AP make sure he doesn't have TWO check valves (bowl and AP cover). verify the diaphragm spring is correctly installed.
    OLDFATGUY
    by OLDFATGUY » Thu Jul 04, 2013 4:44 pm
    will check these things!
