question about suspension
  • aboveall1
    by aboveall1 » Thu Jun 13, 2013 7:56 am
    Has anyone ever ran small wheels on the big wheel bike, longer swing arm etc.
    any info will help.
    Thanks
    by crfsonly » Thu Jun 13, 2013 8:44 am
    Haven't personally been involved in running this set up but I can't think of a reason why it wouldn't work other than reducing ground clearance.
  • aboveall1
    by aboveall1 » Thu Jun 13, 2013 9:13 am
    Thinking more about spring rate and sag, how much different
    by crfsonly » Thu Jun 13, 2013 9:49 am
    valving and spring rates should be the same. race sag as well.
  • ACDNate
    by ACDNate » Thu Jun 13, 2013 11:19 am
    Yah, the factory supplied fork/shock springs are a step stiffer on the RB than the R. If they work with big wheels for the rider, they'll work with the small wheels.
    riddler9
    by riddler9 » Thu Jun 13, 2013 7:00 pm
    It just lengthens the wheelbase a small amount from the swingarm and changes the gearing. You raise the forks in the tree (lower the front end). Only difference between the R and RB is wheel size, chain/sprockets, rear swingarm, and rear brake line.
    Official Lurker
  • aboveall1
    by aboveall1 » Fri Jun 14, 2013 7:49 am
    Thanks for the input guys!
    I talked to Factory Connection and they also said same run the spring rates as we do on big wheel and raise the triple clamps to 8mm. Gearing is always a per track basis anyhow.
