engine oil capacity? and low end bog?
  • der_berger
    by der_berger » Tue Jun 04, 2013 8:44 am
    hey guys just picked up a 05 crf 50 for dirt cheap. i just have a couple questions.
    1. what is the engine oil capacity for an oil change?
    2. i put on a tb 20mm carb kit on it and the bike idles great and the runs good in the upper RPM, but bogs down to almost stalling on the bottom end unless i slowly roll on the throttle. the kit came with a couple other jets. so not sure if re jetting will help this. also the core out of the exhaust is missing.could that be the cause for the low end power bog?
    hazard88
    by hazard88 » Mon Dec 02, 2013 4:04 pm
    I think the kit you are talking about has both pilot and main jets. Pulling the baffle will help it breath a touch better. If the carb you put on has an air/fuel mixture screw you might try adjusting that more on the richer side (counter clockwise). See where you're at first by turning it all the way in and count how many turns you have. If its close to 3 turns out already then you will want to try a larger pilot jet.
