CRF70F air bleed adjustment questions
    Kiwi
    by Kiwi » Thu May 23, 2013 3:33 pm
    1. What is the factory setting for the stock air bleed screw for a 2007 CRF70F? [In other words, from the factory how many turns out from closed was the air bleed screw?]
    2. When riding at altitudes under 3,000 feet ... what is the suggested setting for the air bleed screw for a 2007 CRF70F?
    3. Is it correct that as you turn out (turning counter-clockwise) the air bleed screw that the air/fuel mixture becomes richer?
    2007 CRF450X with modified airbox, Uni filter w/no backfire screen, NCVS needle on 4th, 172 main, CRFs fuel screw at 2, Boyesen QS3, stock smog, 450R cam, FMF Megabomb header, Pro Circuit T-4 muffler, Pro Taper Evo bars, AS suspension
    by Aussiecrf230 » Thu May 23, 2013 8:11 pm
    Do you mean the idle mixture screw being a four stroke(as opposed to an air screw in a 2 stroke)?
    Or are you talking about a seperate screw to adjust the strength of the emulsion near idle? Most air jets are either fixed jets or drilled passages especially in the smaller carbs.
    If you mean the idle mixture screw (with the D head) I believe standard is 1.5 turns out with standard pilot (idle) jet. You still may have to adjust a little each way to run smoothly. This should be done once it has warmed up and off the choke.
    Kiwi
    by Kiwi » Thu May 23, 2013 8:18 pm
    CRF70F = 4-stroke
