impeller removal to replace seal
  • richspencer68
    by richspencer68 » Tue May 07, 2013 2:54 pm
    How do i remove impeller?
  • richspencer68
    removal of impeller continued...
    by richspencer68 » Tue May 07, 2013 3:18 pm
    250x, i understand reverse threads & use 10mm socket but it will not come loose. Reverse means clockwise to remove right? Are there any tips... Help please!
    mrmschmit
    by mrmschmit » Tue May 07, 2013 4:41 pm
    If i remember correctly, you have to jam the gears so it doesnt spin the gears its connected to inside the case. If you do so, be VERY careful not to break off any teeth/damage anything. You are correct, they are left-hand threads (Clockwise to loosen, due to the direction of rotation of the impeller). The torque on the impeller is only 9 foot pounds so be creful not to over tighten when you put it back together. So, since you are talking about taking off the impeller, you are replacing the oil seal for the bearing?? or just the seal for the pump cover? let me know which one and i can help you further. Ps dont lose the little brass colored washer behind the impeller
  • richspencer68
    by richspencer68 » Tue May 07, 2013 5:59 pm
    Awesome will do. I am replacing the coolant seal and should.be fine as long as i can get the stubborn impeller off... Will update soon. Thank you for helping out!
  • richspencer68
    right on!
    by richspencer68 » Tue May 07, 2013 6:05 pm
    Held.the break at the same time and success! Now how to remove the seal?
  • richspencer68
    thank you
    by richspencer68 » Tue May 07, 2013 6:14 pm
    Successful replacement of seal, thanks again!
    mrmschmit
    by mrmschmit » Tue May 07, 2013 6:21 pm
    Alright, good to hear you got it all figured out! Sometimes its just a matter of figuring out what youre workin' with ya know? Glad i could help.
    2007 CRF250R
