crfsonly wrote:keep in mind that "jetting" is not just about the proper jets but also the best needle taper. the needle taper is what meters out fuel from the main jet. so, they work together. this is one of the benefits of the JD kit is it includes two custom tapered needles based on actual dyno and field testing with the specific CRF model and model year. since you want to work with the needle you have consider the following:
1. if you go more than 2 3/4 turns out on the fuel screw go up one size on the pilot jet. This is why i made this post because i have gone up 1 size with no difference in results
2. there are "wear" items in the carb. two that are often overlooked is the emulsion tube or what honda calls the needle jet holder and the needle itself. the needle slides up and down in this tube and will wear both the tube and needle. worn needle and/or tube (more often the tube) you will have these types of symptoms.
I have already replaced the Needle Jet as i mentioned in my post , this is not the issue
3. two other wear items are the floating valve plate and seal. the seal becomes flat or worse and the plate gets worn and no longer functions effectively. the result is less than crisp throttle response and hanging idle. i would start with replacing the seal. we have a how to that will show you the process. both the seal and the plate have a specific orientation.
I replaced the seal last year so it should not be worn out already , since the original one lasted 10 years without issue and it changed nothing when i replaced it then (i found the issue was as i had mentioned , a worn Needle Jet)
4. i don't see the reason to mix the gas you are running. have you tried running straight premium pump gas?
The gas mix is to prevent the gas going bad in a month because of all the crappy Ethanol
5. i recommend installing new jets as part of a process of elimination. it's very difficult to successfully clean pilot jets to new condition. better to eliminate them from the possibilities.
The jets that are in there now are new , and i also cleaned them to make sure that there was no dirt in them or the carb itself , again , that is why i posted , i have done all that should need be to make it run using the correct jets , yet even going up did not change the 3 turn symptom for the fuel screw which seems to be the reason it will not start or idle correctly , this is where i need help
report back with what you find.
crfsonly wrote:if you used carb cleaner that hit the slide you damaged your floating valve seal. so at the very least replace it. if you removed the slide verify the plate is in the correct orientation. you won't be able to see the wear on the needle or the emulsion tube. small amounts of wear have significant impact.
Leardriver wrote:A properly tuned and jetted 450 will pop on decel. There is no way to get rid of it without drowning it in fuel.
The correct main jet for 2000 feet and up is a 162.
