Pilot jet and fuel screw adjustment?
  • Greif8
    by Greif8 » Fri Mar 29, 2013 2:42 pm
    Found out why it was running so poorly. There were two O rings on the fuel screw, one was mangled and the other was pristine. Cant believe it came from the factory like that. Now I am running the stock 45 pilot jet and an R&D fuel screw with the JD jet kit with the 170 jet and the Twin Air filter. The fuel screw when turned all the way in just makes the idle rough, I have to turn it out almost three turns before it starts to have an effect.
    Is this normal for the range of adjustment on the fuel screw?
    Paul
    motosicko
    by motosicko » Fri Mar 29, 2013 3:42 pm
    What bike? <Forget that, I see other post 2012 450X. 3 turns is too much. Try a larger pilot and see if adjustment moves to 2 turns out. 48 seems a little large though. Should be using 42 or 45 depending on elev. and temps in your area.
    "There are old racers
    and there are bold racers,
