robl110 wrote:crazybrother wrote:Yep, as long as you get both top and bottom.
Sweet! Any issues or modifications have to be made to fit the dampner?
robl110 wrote:Ok, I checked out MXBonz and see what your saying. I have an aftermarket light from baja. Is there any other advantage to having the 08 triple other than the damper?
I can get the 08 triple, damper that has been proffesionally valved and the mounting kit for $200 less than a scotts or gpr. I will be dual sporting the bike. Probably 70% pavement/dirt/gravel roads and 30% trails. Would I really gain much benefit by spending the extra money for the scotts or gpr? In other words would the scotts and gpr be over kill?
Thanks, Rob
crfsonly wrote:if it's a stock triple clamp i wouldn't get it just for the offset and HPSD. i'd spend my money to get an aftermarket triple with the Scotts stabilizer. the Applied Racing stabilizer-ready top triple clamp kit with lower triple clamp and a Scotts stabilizer we offer will provide better steering control (triple does flex as much as the stock thereby keeping the forks/wheel pointed where you direct). the Scotts provides far superior stabilizer control.
