cooling / idle problems HELP PLEASE
  • matthewrogerson13@hotmail
    by matthewrogerson13@hotmail » Sat Dec 29, 2012 2:52 am
    Hey guys My names matt i live in wollongong NSW. recently i went for a 2 day ride with a friend over some pretty rocky and rough tracks in the old yalwal mines are we both ride a crf250x mine is 04 his is 08 my mate dropped his bike quite a few times atleast 30 plus times hahahaha and after the ride we noticed quite alot of coolant missing from the system and the bike will no longer idle without the choke.i was just looking to see if anyone could shed some light on the problem before i pull his bike apart.
  • staffy24
    by staffy24 » Sat Dec 29, 2012 3:23 am
    man thats a hard one droping the bike that many times cant be good dose the 250 have a hot start if it dose i bet its jammed open check that first (at the clutch lever)
    over 40 still ridin hard
    still learning
    by matthewrogerson13@hotmail » Sat Dec 29, 2012 3:26 am
    ha ha your telling me mate one of the roughest tracks ive encountered so far both the bikes are a bit worse for wear cheers though i will take a look in the morning
  • staffy24
    by staffy24 » Sat Dec 29, 2012 3:31 am
    yeah when the hot start is open they wont idle and when u drop them you can damage the clutch perch and it can get jammed open also make sure cable is free and working well if thats not the prob check for any air leaks at the carb also if you have been in any water drop the plug from the bottom of the bowl ane run some fuel through
    still learning
    by matthewrogerson13@hotmail » Sat Dec 29, 2012 3:38 am
    she seems to be running fine just wont idle im thinking the idle screw may have got knocked around and the loss of coolant could be due to dropping so so many times
    by matthewrogerson13@hotmail » Wed Feb 27, 2013 10:24 pm
    turned out to be a sticky hot tart combined with a slightly blocked pilot jet
