Clutch Problem
  • alanpolhoatzin
    Clutch Problem
    by alanpolhoatzin » Sun Dec 09, 2012 11:30 am
    Hello,
    Yesterday the bike way fine. I cleaned it and changed oil. But today when I went for a ride and I putted first gear it stalled. As if the clutch was not engaged.
    It is a CRF250R 2004
    Thanks
  • alanpolhoatzin
    by alanpolhoatzin » Thu Dec 20, 2012 7:14 pm
    Bike operates great, but with the bike in neutral if you put it into first with clutch lever pulled, it will stall if you are not giving a little throttle.
    by crfsonly » Thu Dec 20, 2012 7:54 pm
    make sure your idle is set correctly. it's shouldn't not be low. also, make sure your clutch cable is adjusted correctly with the right amount of slack.
  • alanpolhoatzin
    by alanpolhoatzin » Fri Dec 21, 2012 6:28 pm
    I think my idle is correct, the bike is stable. I do not have the proper slack, I will try to fix it. Thank you!
