2003 crf230f low compression
  • PondaRed
    by PondaRed » Tue Jul 31, 2012 12:02 pm
    I just got a used 2003 crf230f - nice shape, but compression is low. 90psi dry, 130psi with oil added.
    What should comrpession normally be?
    So its time for rings. What else should I do while I am in there?
    I really should *not* be spending money on this, so it would be better if I did it on the cheap. Although I like to spend money
  • PondaRed
    by PondaRed » Wed Aug 01, 2012 9:11 am
    Service manual says compression should be 188psi when warm. So I ran it again warm. 100psi, then 140psi with oil.
    I pulled the engine and tore it down (quick to do!). The motor looks great inside. I have a hard time believing there was a problem. I can see the hone marks on the cyl walls. It looks really good. Although I have yet to measure everything.
    Any suggestion on how I can "prove" that the rings failed or the head gasket failed?
