auto decompressin noise??
  • tonyl748
    by tonyl748 » Wed Jul 11, 2012 12:35 pm
    Just installed new head. Timing is good, starts right up, but loud knocking from head. Took valve cover off, and as i rotate the crank the knock is comming from the auto decompression deal on the end of the cam. Anyone know why and what to do about it?
    Thanks
    by crfsonly » Wed Jul 11, 2012 1:55 pm
    sometimes the decomp will make more noise than normal. try lubing the decomp system with oil. apply the oil to all the small working parts (including that little nub that activates the arm) apply a coat of assembly lube to the arm and surfaces if the oil doesn't work.
