2013 CRF450R Announced
    by crfsonly » Tue May 29, 2012 8:42 am
    We'll have more information coming on each of the new models. For now here's a photo of the new 2013 CRF450R:
    What new with the 2013 CRF450R:
    * New frame
    * New swingarm
    * New ighter subframe and airbox
    * New KYB suspension: Forks KYB PSF (Pneumatic Spring Fork) and new KYB shock
    * New dual exhaust system that's more compact and meets current sound limits
    * New six spring clutch
    * New pegs that shed debris and are lighter
    * Increase fuel tank capacity (+ .16G)
    * MX51FA front tire
    * Front and rear brake rotor covers
    * And more!
    2013 Honda CRF450R Specifications
    Model: CRF450R
    Engine Type: 449cc liquid-cooled single-cylinder four-stroke
    Bore and Stroke: 96mm x 62.1mm
    Compression ratio: 12.5:1
    Valve Train: Unicam, four-valve; 36mm intake, titanium; 31mm exhaust, steel
    Induction: PGM-FI, 46mm throttle body
    Ignition: Full transistor with electronic advance
    Transmission: Close-ratio five-speed
    Final Drive: #520 chain; 13T/48T
    Suspension
    Front: 48mm inverted KYB PSF® (Pneumatic Spring Fork) with rebound and compression-damping adjustability. 12.2 inches travel.
    Rear: Pro-Link KYB single shock with spring preload, rebound damping adjustability, and compression damping adjustment separated into low-speed and high-speed; 12.5 inches travel
    Brakes
    Front: Single 240mm disc with twin-piston caliper
    Rear: Single 240mm disc
    Tires
    Front: Dunlop MX51FA 80/100-21
    Rear: Dunlop MX51 120/80-19
    Wheelbase: 58.7 inches
    Rake (Caster Angle): 27° 04’
    Trail: 116mm (4.57 inches)
    Seat Height: 37.5 inches
    Ground Clearance: 13.0 inches
    Fuel Capacity: 1.66 gallons
    Color: Red
    Curb Weight*: 242.7 pounds
    *Includes all standard equipment, required fluids and full tank of fuel—ready to ride.
    Consult owner’s manual for optional parts.
    ©2012 American Honda Motor Co., Inc. • All Rights Reserved
    Specifications are subject to change without notice.
    redrider250r
    by redrider250r » Tue May 29, 2012 10:53 am
    Dual exhaust and a 6 spring clutch! That bike is insane and completely redesigned.
    http://motocrossactionmag.com/mobile/News/FIRST-RIDING-IMPRESSION-2013-HONDA-CRF450-8978.aspx
    Here is the first ride impression.
    "If you don't crash, you ain't goin fast enough"
    "The faster you go, the smoother it gets. (Unless saying #1 comes into play)
    2009 CRF250R (mine)
    09 CRF250R (brothers)
    08 CRF250X (dad)
    mxracer76
    by mxracer76 » Tue May 29, 2012 12:16 pm
    Love everything but the twin pipes. I am curious why they put them on? They already tried this idea a few years ago on the 250F and scrapped the idea and went back to a single.
    I personally dont think we will see the dual exhaust stay around for very long.
    by crfsonly » Tue May 29, 2012 12:23 pm
    mxracer76 wrote:Love everything but the twin pipes. I am curious why they put them on? They already tried this idea a few years ago on the 250F and scrapped the idea and went back to a single.
    sound limits. this is all about meeting the sound limits without negatively affecting performance and/or making really long/heavy muffler. no doubt there will be aftermarket single exhaust available soon as there was when the 250R had duals.
    lightflight
    by lightflight » Tue May 29, 2012 6:50 pm
    So Pneumatic spring forks for the CRF and KXF. I'm interested in seeing what people think of these once they start hitting the market. Both initial impression and how they wear and work down the road.
    twin mufflers... they look pretty cool. Most people I'm sure will end up swapping for a single sided aftermarket exhaust and save some weight in the process.
    The change in the clutch makes me think Honda is listening to consumers. Pretty cool.
    overall I think the bike looks good.
  • dirtae
    by dirtae » Tue May 29, 2012 9:05 pm
    lightflight wrote:So Pneumatic spring forks for the CRF and KXF. I'm interested in seeing what people think of these once they start hitting the market. Both initial impression and how they wear and work down the road.
    Lots of snocross racers like and race the the fox evols (air shocks) on their sleds. They require servicing like any shock. One of the benefits of riding a spring shock though, is that if you have a seal blow out or shock fail, you still have a spring to ride on to finish the race.
    Another benefit is their wide range of tuning. And ease of tuning. One of the negatives to running air or pneumatic shocks on sleds was that the air pressure is affected by temperature. But that will not be much of an issue unless you ride you dirtbike in the winter, and even still, that issue can be addressed simply by adding or taking away air pressure. Which doesn't take long.
    I don't know too much about them but I do know that like everything, some riders will love them, and others will hate them ;)
    This bike looks awesome!
  • Hondacrfrider
    by Hondacrfrider » Fri Jun 01, 2012 1:40 pm
    wow, i was really expecting a hydraulic clutch.
    Bikes in order
    -2009 crf150f (sold)
    -2008 crf230f (sold)
    -2008 crf250x (Dad's bike)(sold)
    -2008 ktm 144sx (mine, sold)
    -2009 crf100f (sister's bike)
    -2012 crf250r (mine)
    -2012 crf250r (dad's)
    lightflight
    by lightflight » Fri Jun 01, 2012 2:33 pm
    sounds like the hydraulic clutch was a factor of cost. I was expecting it as well.
    Bikes are getting way too expensive.
    The more I look at this bike the more I like it. :D
    motosicko
    by motosicko » Fri Jun 01, 2012 8:56 pm
    Just had the opportunity to put my greedy little fingers all over this bike :D Sounds quiet at idle, yet snaps to life very quick. I'm definitely going to own one as soon as available.
    [img][img]http://i405.photobucket.com/albums/pp133/motosicko/IMG_0728.jpg[/img]
    "There are old racers
    and there are bold racers,
    lightflight
    by lightflight » Fri Jun 01, 2012 9:38 pm
    motosicko wrote:Just had the opportunity to put my greedy little fingers all over this bike :D Sounds quiet at idle, yet snaps to life very quick. I'm definitely going to own one as soon as available.
    Looks even Better in a real photo. Lucky.
    redrider250r
    by redrider250r » Sat Jun 02, 2012 8:09 am
    that thing is a sexy beast!! :lol:
    2009 CRF250R (mine)
    08 CRF250X (dad)
    by crfsonly » Sat Jun 02, 2012 8:42 am
    redrider250r wrote:that thing is a sexy beast!! :lol:
    yes, but that rear fender looks like it's going to be a nightmare to ship! ;-)
  • brickmason
    by brickmason » Mon Oct 08, 2012 11:08 am
    Just raced my 2013 at Washougal yesterday. The bike is sooooo much better than my 2011. It corners like a Suzuki I'm so stoked. If i had bought a 2012 a week ago and rode the 2013 id sell the 2012 and buy the 2013. Suspension seems real nice running 35 psi ill try 34 tomorrow at mtn view. The bike is probably going to win the 450 shoot out. Ive ridding all the 2013 bikes. Honda hands down, Kawi and Ktm have the engines still. Hondas engine is much improved clutch is awesome. Turn up your idle though or your gonna stall.
    by crfsonly » Mon Oct 08, 2012 11:46 am
    welcome brickmason to CRF's Only. great review! we are all super stoked about the 2013.
  • JCHarmon23
    by JCHarmon23 » Sat Feb 01, 2014 2:37 pm
    Hello Ladies and Gents,
    New to forum (just bought my first thumper). I recently bought a showroom, 0 hour CRF450R and am 100% stoked to be back on an offroad Honda (I have ridden a 2010 Sabre 1300 for the last 3 years). This bike (CRF450R) is outstanding! I will admit that the last time I rode a dirt bike was in 2002 and it was racing a CR125. Now that that is out of the way, I had a quick question.
    Now that the CRF fuel tank is up to 1.66 gal, what is the ride time before you run out? I am debating buying an oversized tank for it, but need to know facts and data first. Thank you to anyone who takes the time to answer.
Users browsing this forum: No registered users and 11 guests
